KrisW
Mar 23, 2015Aspirant
ReadyNAS NV+ ate my WD20EZRX (2TB Green)?
Hi guys, I bought two WD20EZRX - 00D8PB0 2TB "Green" drives to fit in my NV+ (v1, I guess - the PCB still says "Infrant"). The WD Green 20EARX model is on the compatibility list, and the EZRX sho...
KrisW
Mar 25, 2015Aspirant
Okay...
Factory reset resulted in the unit hanging at "Booting...", so I performed a USB Restore of the Raidiator4.1.8 firmware onto the NAS instead.
Now, on reboot, with the WD disk in bay 3, I get an "ERR: No Disks" on the LCD display. RAIDar tells me the same thing. "Setup" isn't available
The four LED indicators blink in this sequence: ".*..", "....","****","...." (Bay 2 lit, all off, all on, all off).
I repeated the test with the WD disk in Bay 1, and got the same result.
