nwwoods
Jul 15, 2017Aspirant
ReadyNAS NV+ data recovery one bad disk
ReadyNAS NV+ v1, frontview 4.1.16, 4 1TB Samsung spinpoint drives, X-RAID (3 data drives, 1 parity AFAIK) It all started with noticing vast swaths of files/directories seemed to no longer be pres...
Jul 16, 2017Guru - Experienced User
When you booted with disk 1 inserted, did you look at the status with RAIDar?
Maybe power down, insert it again, and try booting using the "skip volume check" option.
The RAID array can be mounted in an x86 linux system: http://home.bott.ca/webserver/?p=306
- nwwoodsJul 16, 2017Aspirant
Thanks for responding.
With disk 1 inserted, RAIDar showed the disk healthy, but I got connection refused from Frontview or browsing. The only way I could rouse Frontview was with only disks 3,4 inserted.
I was able to boot with 3,4 and add 1,2 and Frontview showed them, but resync was grayed. I used the debugger to enable it and start a resync, but the resync failed. Not surprising.
I did go farther back in the logs and noted an alert about disk 1 from way back in April. Combined with the recent fail on disk 2, 2 failed disks from ReadyNAS' point of view, so no wonder.
The drives are all readable as I mentioned before, with ext2-explorer. I bought R-Studio and can read each of the drives with it also. I bought a pair of 2TB drives and did a factory reset so I basically have a fresh ReadyNAS. Am working through the original disks one by one on a PC with R-Studio and recovering. backup share from Disk 1 in progress now. It says 8 days to finish. Recovered contents so far are good. Guess I could have gone the Ubuntu route per http://home.bott.ca/webserver/?p=306 and saved 80 bucks bu R-Studio looks real nice and reminds me of Norton Utilities from the old days.
At least the drives seem to be independent so I can recover them one at a time. I thought X-RAID with 4 disks was RAID-5 like, but so far I don't see any striping, thankfully. It's just going to take a long time.
- StephenBJul 17, 2017Guru - Experienced User
There is striping with XRAID (which on an NV+ is using RAID4 - dedicated parity disk)
- nwwoodsJul 17, 2017Aspirant
Thank you StephenB. Fascinating.
How does the block level striping work at the file level? Assuming 1MB blocks for SAMBA, I would expect a 3MB file to be split across 3 disks in a 4-disk system. But what I am seeing is mp3's and jpegs in that size range are fully on the one disk. Just restored a 3GB mpeg also from the same disk.
