fooprobe's avatar
fooprobe
readynas nv+ dead, how to recover disks?
my trusty NV+ finallky quit.  not in the serial number range for the PSU service action.  i have a backup, but it's a hassle because the backup doesn't delete old folders when i move them around on the RAID, so there are a lot of old folders hanging out on the backup and i'd have to sort through manually to find the most recent ones.
any suggestions on recovering the disks?  is there a readynas i could migrate the disks to? i actually don't think i need a RAID anymore, kind of overkill for my use, but i don't know if there's any other way to recover the disks besides plugging them into a new chassis.
any thoughts?
-emil
  • Emil,
        I take it power supply is dead. If you know someone with an active NV+, or search for a PSU.
        The later x86 and ARM units are not compatible with Sparc NV+.
          Regards, Marto
    • fooprobe's avatar
      fooprobe
      i don't know for certain that the PSU is dead but it looks like it.  i get no lights at all, unresponsive.
      i was afraid that's what you would say =(  ok, thanks for the feedback.
ProSupport for Business
