MurrayMartin
Oct 11, 2011Guide
ReadyNAS NV disk upgrade from 1.2tb to 8tb
I have been trying unsuccessfully to upgrade my existing 4x400 system to 4x2000 Using RAIDar 4.1.8 The 2tb drives are WD20EARS-11J2GB0 I have tries a factory reset with 4 drives. This does not wo...
mdgm-ntgr
Oct 11, 2011NETGEAR Employee Retired
Could you hook the drives up to a SATA port on your PC and check them using vendor tools?
