MurrayMartin
Oct 11, 2011Guide
ReadyNAS NV disk upgrade from 1.2tb to 8tb
I have been trying unsuccessfully to upgrade my existing 4x400 system to 4x2000 Using RAIDar 4.1.8 The 2tb drives are WD20EARS-11J2GB0 I have tries a factory reset with 4 drives. This does not wo...
MurrayMartin
Oct 24, 2011Guide
Yes
I have tested them on my PC as SATA drives and they work fine
however the resync on the secon drive is runnubg at 1K, therefore about 20 days per drive
The 1st one installed fine
