cwietholt
Feb 16, 2013Aspirant
ReadyNAS NV+ does not power on anymore
Today, I shutdown my 4 year old ReadyNAS NV+ to move it to a different location. Now it won't turn on anymore. I assume that the power supply is done. Is there a way to get a refurbished power supply,...
mdgm-ntgr
Feb 16, 2013NETGEAR Employee Retired
Contact tech support and post your case/RMA number (whichever you get). If it is under warranty (or if the serial is in this range: http://www.readynas.com/forum/viewtopic.php?p=54911) you should be able to get a replacement PSU.
