jimbo6001
Sep 11, 2020Aspirant
ReadyNAS NV+ does not turn on - HELP!
Hello there, I have a ReadyNAS NV+ and it has been working fine for yeas but we had the power turned off at our place the other day for some electrical work and when the power was turned back on the...
jimbo6001
With regard to a replacement PSU, this would just be a straight swap over with another NV+ compatible unit wouldn't it? (You mentioned modifying the pin out?). Could you send me the cable / pin-out details for the external ATX power supply option as well? Thanks for your help, James
Sep 12, 2020Guru - Experienced User
The pinout is attached - the cable details would be the same for an external ATX. There are some mini-ITX, (also called flex ATX) supplies out there that might fit, but they would also need the mod.
Of course if you are taking the PSU from another NV+ (or purchase one that is pre-modified) there would be no modification needed.
There is more info on this here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Inexpensive-power-supply-replacement-for-legacy-4-bay-Readynases/m-p/1253813#M18665
