jimbo6001
Sep 11, 2020Aspirant
ReadyNAS NV+ does not turn on - HELP!
Hello there, I have a ReadyNAS NV+ and it has been working fine for yeas but we had the power turned off at our place the other day for some electrical work and when the power was turned back on the...
jimbo6001
Sep 12, 2020Aspirant
Hi again,
I tired following the PSU removal instructions (attached) which I found on this forum and I am able to remove the side panels and the fan but for the life of me I cannot remove the PSU and chassis! I have removed all screws as per the instructions but the PSU chassis will not slide out - Can anyone advise if I am doing anytning obvious or there is an additional step I need to action?
Thanks for the continued assistance.
James
Sandshark
Sep 12, 2020Sensei
Did you forget the screw under the tamper-proof seal? I have an NV+ V1 sitting right here with the supply removed, and the instructions cover everything.
BTW, the supply for a Pro4, Ultra4, or NVX will also work, though you can probably buy a used NV+ cheaper.
