arcturus1
Oct 27, 2013Aspirant
Readynas NV+, fans only when powered on
My home was hit by lightning. I had my Readynas and all other equipment on UPS's. Unfortunately, I believe the strike managed to ride my home ethernet, and blew out a lot of things connected to it. ...
Oct 27, 2013Guru - Experienced User
The NV should be able to access the data. Label your disks by slot #. Use a scratch disk in the NV to update the firmware (if it is running something old...) Pop in the scratch disk by itself, update the firmware, and shut down. Then install your disks in slot order, and power up.
You can also use the scratch disk to downgrade the firmware to the original version (if it is not too old).
An alternative to the scratch disk is to simply update your friend's system before you begin.
Haw many disks are installed btw?
