arcturus1
Oct 27, 2013Aspirant
Readynas NV+, fans only when powered on
My home was hit by lightning. I had my Readynas and all other equipment on UPS's. Unfortunately, I believe the strike managed to ride my home ethernet, and blew out a lot of things connected to it. ...
arcturus1
Thanks for the info. As far as scratch disk. You just mean a random hard drive that works with the readynas I assume? The drives in the other nv or nv+ still work. They are just all failing and made the unit unstable. I can boot up enough to update the firmware I believe.
In my unit I have 4 x 2tb drives.
So basically get the other one up to latest firmware, and then put my drives in order and I should be good to go? Of course assuming my hard drives are good.
