arcturus1
Oct 27, 2013Aspirant
Readynas NV+, fans only when powered on
My home was hit by lightning. I had my Readynas and all other equipment on UPS's. Unfortunately, I believe the strike managed to ride my home ethernet, and blew out a lot of things connected to it. ...
Oct 27, 2013Guru - Experienced User
Yes - the scratch disk can be any reasonable SATA drive. You won't be setting up RAID on it. If the firmware on the NV doesn't match the NV+, then the NV will attempt an OS reinstall - which you don't want.
