arcturus1
Oct 27, 2013Aspirant
Readynas NV+, fans only when powered on
My home was hit by lightning. I had my Readynas and all other equipment on UPS's. Unfortunately, I believe the strike managed to ride my home ethernet, and blew out a lot of things connected to it. ...
Oct 29, 2013Guru - Experienced User
If it sees a mismatch, you will get an OS reinstall.
Anything between 4.1.10 and current will likely work - where you get into trouble is when the firmware on the NAS is really old (so you cannot go back).
