hby
Sep 17, 2015Aspirant
Readynas nv+ hangs
My ReadyNAS NV+ have suddenly started to hang/freeze. When I power on the unit works for a while but suddenly it hangs. The power button is blue and all disk LEDs are green but when i press the powe...
Sep 17, 2015Guru - Experienced User
It sounds like a filling OS partition. If you still have SMB access, make a backup.
Do you have ssh enabled?
Also do you have ReadyDLNA running?
- hbySep 19, 2015Aspirant
Hello Stephen.
If the problem is a filling OS partition, what should I do to correct it?
I don't know if ssh is enabled. When I try to access the nas with ssh I get the response
"ssh: connect to host 192.168.1.100 port 22: Connection refused" and I do not know where port
22 has to be activated (My Mac, wireless router, Nas unit). I am not that experienced on network/operating system.
Maybe it is my router who denies access on port 22?
I guess ssh is for log in on the Nas unit and do something.
Yes ReadyDLNA and ITunes streaming server is active.
The most important data is already copied to a external disk.
Regards
HÃ¥kan B
