hby
Sep 17, 2015Aspirant
Readynas nv+ hangs
My ReadyNAS NV+ have suddenly started to hang/freeze. When I power on the unit works for a while but suddenly it hangs. The power button is blue and all disk LEDs are green but when i press the powe...
JennC
Sep 18, 2015NETGEAR Employee Retired
Hi hby,
Welcome to the community!
In addition to Stephen's questions, does the RAIDar see the NAS?
Since you have checked the disks with diagnostic tools, please make sure you insert them back to thier respective bays.
If RAIDar does not see the NAS, check the cable between the NAS and the switch/router where it is connected, make sure both ends are properly plugged in.
hby
Sep 19, 2015Aspirant
Hello.
Yes RAIDar see the Nas.
It is like this.
All is working normal for a while (a couple of hours) and then it hangs again.
Then you have to switch off power on the back and on again.
When you switch on the nas unit it detects the powerbreak and starts to syncronize the disks, that goes well.
It also asks that you should check filesystem by rebboting it, that goes well too.
So after that two actions I open the logs in the Nas to see if anything is wrong but everything is reported okey.
Then suddenly after some hours it has stopped working and is hanged.
Regards
Håkan B
- StephenBSep 19, 2015Guru - Experienced User
You could lose all access to the NAS soon, so if you have no backups you really should be making them.
It sounds likely to be a filling OS partition to me. If I am right, you would need to enable ssh on the NAS (and feel comfortable using it) to resolve the problem yourself. Another option is to do a factory reset, and rebuild the NAS/restore the data from backup.
It would be easy for Netgear to solve, so if you are the original purchase you could try contact supporting (and pay a per-incident support fee).
- hbySep 19, 2015Aspirant
Hello Stephen.
Now I have enabled ssh and have logged in on my ReadyNAS.
The command df shows:
hakan-nas1:/var/log# df
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/hdc1 2031872 835664 1196208 42% /
tmpfs 16 0 16 0% /USB
/dev/c/c 5825235232 1139718496 4685516736 20% /c
/c/backup 5825235232 1139718496 4685516736 20% /home/ftp/backup
/c/hakan 5825235232 1139718496 4685516736 20% /home/ftp/hakan
/c/media 5825235232 1139718496 4685516736 20% /home/ftp/media
Is there anything interesting in /var/log/messages?
Regards
Håkan
- JennCSep 19, 2015NETGEAR Employee Retired
Hello hby,
I checked your profile and found that your ReadyNAS NV+ is a v1 and its hardware warranty as well as support are already expired.
Have a full backup of your data. Once done, it may be best you do the factory reset. Or wait for mdgm if he can take a look remotely.
