hby
Sep 17, 2015Aspirant
Readynas nv+ hangs
My ReadyNAS NV+ have suddenly started to hang/freeze. When I power on the unit works for a while but suddenly it hangs. The power button is blue and all disk LEDs are green but when i press the powe...
Sep 21, 2015Guru - Experienced User
hby wrote:
hakan-nas1:/var/log# df
Filesystem 1k-blocks Used Available Use% Mounted on
/dev/hdc1 2031872 835664 1196208 42% /
Normally I'd expect ~20%, but this is not full enough to hang the NAS.
I think JennC is correct, a factory reset (after you complete the backup) is the best next step. Or buy a new NAS (under the theory that the NV+ hardware might be starting to fail).
hby
Sep 21, 2015Aspirant
Hi.
I have decided to buy a new NAS (made it yesterday).
Thanks for your help.
Regards Håkan Bystam
- DaneASep 21, 2015NETGEAR Employee Retired
Hi hby,
I am glad that you bought a new NAS which is an RN102 as it shows into your profile.
Just curious if you were able to transfer you data and access it just fine using your new RN102. Feel free to contact NETGEAR Support at anytime if you need assistance.
DaneA
NETGEAR Community Team
- hbySep 22, 2015Aspirant
Hi Dane.
I am tranfering my data right now. My old Nas has stopped a couple of times but a restart and a new copy command has completed the copy.
Hakan
- StephenBSep 22, 2015Guru - Experienced User
After everything is moved, perhaps try a factory default on the NV+. If it becomes stable again, you can use it to backup the RN102.
