organleroy
Oct 16, 2014Aspirant
ReadyNAS NV+ hangs/freezes; please help diagnose #24042647
My ReadyNAS NV+ has started hanging/freezing after being powered on for 30-90 minutes. Once it hangs, I can't access it via Frontview or SSH and there's no way to restart it other than pulling the plu...
mdgm-ntgr
Oct 16, 2014NETGEAR Employee Retired
Do you have a friend with a PC that could help?
As well as testing the disks I would recommend running the memory test boot menu option a few times.
To run the memory test:
1. Power off the ReadyNAS
2. Press and hold the POWER button. Roughly every 5 seconds a new boot menu option will appear and the disk LEDs will blink. Release the power button after you see the memory test option.
