JGumley
Dec 22, 2010Follower
ReadyNas NV+ Hitachi 3TB Drives.
I just purchased a ReadyNAS NV + 4 Bay, inserted 2 existing Hitachi 3TB Hard Drives (No Data on them) that I had in my old computer, powered everything on and now the Hard Drives read as 768Gb in size...
mdgm-ntgr
Feb 16, 2011NETGEAR Employee Retired
JessKaufman wrote: Thanks for the reply, but the largest portion of my question is still unanswered .. and that is, which models are x86?
Most of the NetGear models are. The Duo, NV+ and 1100 are Sparc ReadyNAS though.
Currently the x86 models include, the NVX, Ultra Series, Ultra Plus Series, Pro, Pro Series, 1500, 2100 3200, 3100 and 4200
JessKaufman wrote:
I looked at the comparison sheets, and it seems that the ReadyNas Ultra series have intel duo core processors, so would that be a compatible model that the beta firmware will work on?
The Ultra Series have Intel Atom processors, some have single core, others have dual core. The Ultra 6 Plus has a Pentium Dual Core. Take a look at CPU Specs of the ReadyNAS
The 4.2.16 beta firmware will run on all x86 ReadyNAS.
