AndrewWykes
Mar 07, 2021Aspirant
ReadyNas NV+ Overheated - how do I salvage my data?
I have had this machine for years and has worked well. Recently, due it it being dusty (my fault), it seems to have overheated and now won't switch on. To sure if it has a fuse or it's the power sup...
AndrewWykes
Mar 10, 2021Aspirant
sorry daft question - which version of R-Studio. There are 5!
Mar 11, 2021Guru - Experienced User
The $79 license will certainly work. You might be able to use the $49 or $59 version - not sure.
