mann238
Oct 19, 2013Follower
ReadyNas NV+ power supply failure
hi, my 5 year old readynas NV+ power supply failed today. is it worth replacing the power supply or should i use this opportunity to upgrade to a ReadyNAS 104 diskless? my current drives are 4 ...
mdgm-ntgr
Oct 19, 2013NETGEAR Employee Retired
No. The RAID format is different
Is your serial in this range?: http://www.readynas.com/forum/viewtopic.php?p=54911
Can you login to my.netgear.com and check your warranty status?
