azenone
Jun 28, 2012Aspirant
ReadyNAS NV power supply issue
howdy,
d
I have an Infrant ReadyNAS NV with a bad power supply. The original ps was replaced with a fanless unit some time ago, three years ago maybe, and now the replacement has died as well. Is there any chance that Netgear will replace this part again? The serial number is missing as Netgear had requested that I send them the original ps tray with the original bad ps, and the replacement tray was blank. The Netgear part number on the power supply 331-10006-02, it that helps at all.
thanks.
d
thanks.
- ReadySECUREApprenticeThe power supply replacement for this unit was most likely covered under this issue. I am sorry to say it only covers one replacement and all of the ReadyNAS covered are out of warranty.
We can still try looking it up to see if there is something we can do. Could you PM me the RMA number, MAC addr, or any information you registered it with so I can look into it for you? - PapaBear1ApprenticeThis item from Amazon may be your best bet. Their prices (directly from Amazon, not a third party) have always been reasonable. I bought one last January and it is still on the shelf at this point. They come and go in stock. Netgear used to list them in the Netgear Store, but my link to that listing no longer works.
- azenoneAspirantThanks PapaBear, if all else fails I will give that a go.
