justinlu
Dec 15, 2019Aspirant
Readynas NV+ Problem
Hi guys, I recent had a problem with my readynas NV+.(4xWD 2TB) two weeks ago I had a power cut. after power back, I turned on the nas, on front panel it showed 'kernel panic', couldn't access in...
Dec 15, 2019Guru - Experienced User
Do you have a backup of the data? If you don't, then make one before you try anything else.
Perhaps download the log zip file, and look at the disk health for disks 1-3 in disk_smart.log. Also test the new WD20EFAX in a windows PC with WD's lifeguard program. You can connect it with either SATA or a USB adapter/dock.
