justinlu
Dec 15, 2019Aspirant
Readynas NV+ Problem
Hi guys, I recent had a problem with my readynas NV+.(4xWD 2TB) two weeks ago I had a power cut. after power back, I turned on the nas, on front panel it showed 'kernel panic', couldn't access in...
Dec 15, 2019Guru - Experienced User
Do you have a backup of the data? If you don't, then make one before you try anything else.
Perhaps download the log zip file, and look at the disk health for disks 1-3 in disk_smart.log. Also test the new WD20EFAX in a windows PC with WD's lifeguard program. You can connect it with either SATA or a USB adapter/dock.
justinlu
Dec 16, 2019Aspirant
I have download the log, seems disk 1-3 are fine. and used WD's lifeguard program to test the 'dead disk 4' and the new disk 4, both passed.
now, i hot inserted the old disk 4, front panel shows ip address and disk4 sync and i can see the readynas in raidar but couldn't access the frontview.
***** Disk SMART log from 2019/12/16 *****
***** Disk SMART log for channel 1 [hdc] *****
smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M0VSUKAU
LU WWN Device Id: 5 0014ee 20f5c92b8
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ACS-2 (revision not indicated)
Local Time is: Mon Dec 16 22:16:46 2019 NZDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (26940) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 113
3 Spin_Up_Time 0x0027 173 173 021 Pre-fail Always - 4350
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 7
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13286
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 7
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 5
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 13330
194 Temperature_Celsius 0x0022 120 105 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** Disk SMART log for channel 2 [hde] *****
Model Family: Western Digital Caviar Green (Adv. Format)
Device Model: WDC WD20EARX-00PASB0
Serial Number: WD-WCAZAD757772
LU WWN Device Id: 5 0014ee 206a2211b
Firmware Version: 51.0AB51
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Dec 16 22:16:52 2019 NZDT
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
been run.
data collection: (36360) seconds.
command.
power-saving mode.
SCT capabilities: (0x3035) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 166 162 021 Pre-fail Always - 6683
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 119
9 Power_On_Hours 0x0032 012 012 000 Old_age Always - 64680
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 115
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 110
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 4280890
194 Temperature_Celsius 0x0022 124 104 000 Old_age Always - 26
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** Disk SMART log for channel 3 [hdg] *****
Serial Number: WD-WCAZAD763176
LU WWN Device Id: 5 0014ee 25bf74a08
ATA Version is: 8
Local Time is: Mon Dec 16 22:16:58 2019 NZDT
been run.
data collection: (38160) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 168 167 021 Pre-fail Always - 6558
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 128
9 Power_On_Hours 0x0032 010 010 000 Old_age Always - 65893
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 126
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 125
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 3388005
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** Disk SMART log for channel 4 [hdi] *****
Smartctl: Device Read Identity Failed: empty IDENTIFY data
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
- StephenBDec 16, 2019Guru - Experienced User
justinlu wrote:
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3Disk 1 is showing some errors, so you should keep an eye on it.
A better plan would have been to insert the new disk by itself in slot 1, then set up the NAS. After that try powering down and move the disk to slot 4, and confirm that it boots. That would have isolated the issue to the disk or the SATA bus in the chassis.
However, another possibility is that the NAS set the SATA interface to down, because something unusual happened on the interface. Rebooting the NAS would clear that.
It's not unusual for Frontview to become inaccessible during a resync of an old NAS - it runs at a lower priority than the rest of the system, which is busy doing the resync. At this point, just wait a while, and see if it comes back. Hovering over the disk in RAIDar will give you an estimate of the progress. Note the estimated completion times are often wildly wrong, what matters here is if the sync is progressing.
- justinluDec 16, 2019Aspirant
Thanks for the reply.
Disk 1 (WD RED) is about 1 years old, how come has error already? while the other 2 (WD GREEN) still fine for years.
I have tried what you siad. New disk in slot 1 boots ok, and moved to slot 4 no problem too.
So what should I do now? put 3 disks back and insert new disk to slot 4?
So both slots are working, and the disk is ok.
I'd put the three disks back in, and make a backup. The try hot-inserting disk 4 again.
