justinlu
Dec 15, 2019Aspirant
Readynas NV+ Problem
Hi guys, I recent had a problem with my readynas NV+.(4xWD 2TB) two weeks ago I had a power cut. after power back, I turned on the nas, on front panel it showed 'kernel panic', couldn't access in...
Dec 15, 2019Guru - Experienced User
Do you have a backup of the data? If you don't, then make one before you try anything else.
Perhaps download the log zip file, and look at the disk health for disks 1-3 in disk_smart.log. Also test the new WD20EFAX in a windows PC with WD's lifeguard program. You can connect it with either SATA or a USB adapter/dock.
justinlu
Dec 16, 2019Aspirant
i have downloaded the log and seems disk 1 to 3 are all good. also runned wd lifeguard programme, the old disk 4 and new disk 4 both passed. so what's the problem?
now i hot inserted old disk 4 back to nas and front panel showing ip addree and disk 4 sync. meanwhile i can see nas in raidar which i couldn't before, i will take it as good sign. though can't access the frontview.
***** Disk SMART log from 2019/12/16 *****
***** Disk SMART log for channel 1 [hdc] *****
smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M0VSUKAU
LU WWN Device Id: 5 0014ee 20f5c92b8
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ACS-2 (revision not indicated)
Local Time is: Mon Dec 16 22:16:46 2019 NZDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (26940) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 113
3 Spin_Up_Time 0x0027 173 173 021 Pre-fail Always - 4350
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 7
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 082 082 000 Old_age Always - 13286
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 7
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 5
193 Load_Cycle_Count 0x0032 196 196 000 Old_age Always - 13330
194 Temperature_Celsius 0x0022 120 105 000 Old_age Always - 27
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
***** Disk SMART log for channel 2 [hde] *****
Model Family: Western Digital Caviar Green (Adv. Format)
Device Model: WDC WD20EARX-00PASB0
Serial Number: WD-WCAZAD757772
LU WWN Device Id: 5 0014ee 206a2211b
Firmware Version: 51.0AB51
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Mon Dec 16 22:16:52 2019 NZDT
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
been run.
data collection: (36360) seconds.
command.
power-saving mode.
SCT capabilities: (0x3035) SCT Status supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 166 162 021 Pre-fail Always - 6683
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 119
9 Power_On_Hours 0x0032 012 012 000 Old_age Always - 64680
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 115
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 110
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 4280890
194 Temperature_Celsius 0x0022 124 104 000 Old_age Always - 26
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** Disk SMART log for channel 3 [hdg] *****
Serial Number: WD-WCAZAD763176
LU WWN Device Id: 5 0014ee 25bf74a08
ATA Version is: 8
Local Time is: Mon Dec 16 22:16:58 2019 NZDT
been run.
data collection: (38160) seconds.
command.
power-saving mode.
3 Spin_Up_Time 0x0027 168 167 021 Pre-fail Always - 6558
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 128
9 Power_On_Hours 0x0032 010 010 000 Old_age Always - 65893
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 126
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 125
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 3388005
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
***** Disk SMART log for channel 4 [hdi] *****
Smartctl: Device Read Identity Failed: empty IDENTIFY data
A mandatory SMART command failed: exiting. To continue, add one or more '-T permissive' options.
ATA Version is: 8
was never started.
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
ATA Version is: 8
been run.
command.
power-saving mode.
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
