blong2000
May 19, 2019Aspirant
ReadyNAS NV+ refused to connect
I have a ReadyNAS NV+ (firmware 4.1.16) with 4 HDD's populated that is giving me "refused to connect" error messages when I try to access the admin page from Chrome or Internet Explorer (using Window...
blong2000
Thanks for the response. When I do a "net use" command from a command prompt, I see that windows still believes that the shares exist, but that they are unavailable to me. That, unfortunately, is about the only proof I have that the shares still exist.
Regarding paid support...if that's what it takes, I'm fine with it. It's a small price to pay to get access to the files on the NAS again. (I do run backups...but it has been a few months since the last one.) Is there a recommended way to engage with Netgear about remote support at a price?
Thanks, Brian
May 20, 2019Guru - Experienced User
Perhaps try this, and see what happens:
net use * /delete net use t: \\nas-ip-address\C /user:admin nas-admin-password
That will attempt to mount the C volume as drive letter T. Be careful on the typing (both spaces and slash direction).
If you have some familiarity with Linux, you could also attempt to access the linux CLI in tech support mode, and mount the data volume manually. If that works ok, you can back up the data.
Another thing you can do on your own is connect the disks to a Windows PC and use RAID recovery software. This would likely require purchase of USB adapters/docks.
You can use my.netgear.com. You can ask about per-incident support (which should be a bit cheaper then a full support contract).
