arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
SamirD
Dec 17, 2022Prodigy
It really depends on what your goal is at this point. If you have a backup of the data and simply want to restore the nas, I would 'nuke it from orbit' and start again, just reset it it with one wiped drive and rebuild from there.
arefem
Dec 30, 2022Star
The message has moved on to 'resyncing disk 2', but has been stuck at that for several days. I've decided to move on and replace the disks. My brother might have a go at the Linux recovery route, but at the moment, I'm going to start afresh with new disks to create a blank system, and install the out of date backup, and then re-build. My question now is, is there a procedure for adding the new blank disks that will preserve the existing NAS settings?
