Brco33
Mar 11, 2019Aspirant
REadynas NV+ Stuck in Booting Process
Hey Everybody,
I seem to be experiencing the often discussed issue of my readynas NV+ getting stuck on the booting screen. I did the memory check and passed, drive health appears to be fine. Th...
Mar 11, 2019Guru - Experienced User
First see if you can boot up the NAS into "tech support" mode. See pages 23-24 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
If this still works:
- You can still engage Netgear support via my.netgear.com. You'd boot up the NAS in tech support mode, and Netgear can support it remotely. Cleaning up a full OS partition isn't that difficult for them. Ask for per-incident support.
- You can also access the NAS with telnet if you are in tech support mode. However you would need reasonable linux skills (and now isn't a good time to learn linux).
If you can't boot into tech support mode, then it gets more complicated. The USB recovery process carries some risk, so I don't recommend trying that at this point. It's not clear that the flash is corrupted anyway.
If you get a new NAS, Netgear's paid support can help you mount the old disks temporarily so you can offload data.
Brco33
So, I was able to boot in tech support, it showed the debug ID and the IP address. When I tried calling 888netgear, it told me to go online and create a ticket and hung up. Going to create a ticket on support.netgear puts you in the path of buying a service contract. The shortest duration is 1 year.
There is a gear head tech support option. I can do 6 months for that, but I saw a link explaining that they do have a per instance plan, but that didnt look available.
Is there another way to go about it? I looked to be walled in unless I buy a 6mo or 1yr service plan. I dont know enough about gearhead to know if they'd even be able to resolve it.
- StephenBMar 12, 2019Guru - Experienced User
Getting paid support is still just too hard. I wouldn't use gearhead for this.
Try emailing customer.service@netgear.com, and see if they can offer you per-instance support.
- Mar 27, 2017Retired_Member
