eggman1
Apr 18, 2012Aspirant
ReadyNAS NV+ v1 and 2TB Drives - Help Please
Hi Folks, I have done some reading on here, but 4k blocks and 16k sectors is making my brain hurt. Some help would be much appreciated. I currently have a NV+ v1 with Raidiator 4.1.8. I have 4 x...
mdgm-ntgr
Apr 18, 2012NETGEAR Employee Retired
eggman wrote:
1. How important is it to use the 4k block size?
You need the 16k block size
eggman wrote:
2. Do I need 4k sector alignment?
Yes. Your new disks are 4k sector disks. Don't confuse 4k sector partition alignment with the block size of the volume.
eggman wrote:
3. How can I tell if I have 4k sector alignment?
The article I linked to explains how. However considering the block size of your volume is 4096 that means you last did a factory default on RAIDiator 3.x so your partitions would not currently be 4k sector partition aligned. You will need to backup your data and do a factory default.
eggman wrote:
4. Any recommendations on the best way to perform a backup process for this? I don't have an unlimited supply of data storage :)
Backup to another NAS, USB disks, drives connected to your PC or some place else. It depends what suits you which method you would use.
eggman wrote:
I have a drive connected to the USB interface and back up critical data regularly, but I don't want to go through a full 2.7TB backup -> factory reset -> data restore process unnecessarily, or more than once.
Only need to do the backup and factory reset once.
