SAMBASANCHEZ's avatar
SAMBASANCHEZ
Follower
Oct 04, 2020
ReadyNAS NV+ V1 Not powering on
Hi Netgear Community,
I have a Ready NAS that just quit working on me. I have reasearched online and it seems the PSU is out. This unit is obviously old, but it was working with no problems. I was wondering if I can send it somewhere and have it fix, or maybe just get the PSU and replace it myself. I even disconnected the Cr2023 Battery as suggested in another forum, but I had no luck.
Any advice will be appreciated.
Thanks,
  • StephenB's avatar
    It is possible to replace it, but if you use an off-the-shelf supply you need to make a modification in the cable.  I've attached a pdf showing the wiring.
    There are a couple out there on ebay and other sites that already have the wiring change (at least the sellers say they do).  The Netgear part was RND4PSU1-10000S (part number was 332-10384-01).
    • Sandshark's avatar
      Sandshark
      Sensei
      If you have decided that it6's time to upgrade, anyway, you can also make an adapter cable to go from a standard ATX supply to the NAS, swapping/removing pins per the drawing StephenB attached.  You can mount that externally and allow you to download the files to your new NAS or a backup device.  Just use masking tape or similar to cover the gap the cable runs through in the back so as to keep the airflow right for the drives.
ProSupport for Business
