Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
Lilja
Thanx for your detaild reply.
I have tryed to run Os reinstall with no luck.
Not all files are on backup at the monent (but working on it). The os on the Nas was 5.3.2 and still is.
It did try to update the firmware but it did roll back when it did not succed i guess. But someting did get messed up.
I have also tried to update to newer firware manually but aim not allowed. System fail is all i get when i try.
The sad thing is that i have used tons of time to set up the NAS and sort all information so i really do not want to run factory reset
And if i do how long til it does get messed up agein? I would really like to se a bug fix to be sure that all is ok for the future.
And as i mentiond the support i have recived i really good. And they have promised to get back to me with more help.
But aim sure that aim not the only one with this problem?
Olof
Olof
