Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
mdgm-ntgr
Jan 31, 2012NETGEAR Employee Retired
I don't know how it happened and now you've done a factory default on your system I'm not sure NetGear tech support would be able to work out for sure either.
It shouldn't happen again. A factory default is a last resort if all else fails and is rarely needed.
