Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
Lilja
Feb 02, 2012Aspirant
Things is getting better and better.
This morning i woke up to this message:
Disk failure detected. (nas-A0-56-48)
Did reboot and run volyme scan and disk is back and rebuilding.
Now someone tells me that one might have to run a firmware update on my discs to fix the problem.
I have greenline discs and what i was told now is that they respond to slow and that can cause the problem?
Seagate ST2000DL003-9VT166
But i have seen lots of geople using and recomending them. And it dont seams like they have any problems?
Thu Feb 2 10:38:47 CET 2012Data volume will be rebuilt with disk 1.
Thu Feb 2 10:38:44 CET 2012Volume scan found and corrected errors
Thu Feb 2 04:39:50 CET 2012 Disk failure detected.
Please advice.
Olof
Please advice.
Olof
