Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
mdgm-ntgr
Feb 02, 2012NETGEAR Employee Retired
Your disks are not on the Hard Disk HCL and may be incompatible.
Please download your logs (Status > Logs > Download all logs) and extract the zip contents and look in the "disk_smart" log. What is the firmware version for the disks listed? My ST2000DL003-9VT166 disks have firmware CC32.
Also are you able to connect the disks up to a SATA port on your PC and check the disks using SeaTools?
