Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
mdgm-ntgr
Feb 02, 2012NETGEAR Employee Retired
SeaTools can be used to verify if you have a bad disk.
Yes, it is very likely that these disks are incompatible with the v2.
