Lilja
Jan 29, 2012Aspirant
Readynas NV+ V2 Device is offline # 17773704
Did get a new Netgear readynas NV+ V2 the other day. Did work good in the start but after two days use i did get a question to update the firmware in the webcontrole for the nas. I did update it and ...
Lilja
Feb 03, 2012Aspirant
Ok. By that you say that i put my old discs in the new nas and do a factory reset?
Then it will clear the discs and update firmware etc. Seams like a good idea.
Thanx.
Thanx.
