sebbelcher
Mar 11, 2019Aspirant
ReadyNAS NV+ v2 disk addition questions
I have an NV+ v2 running a 2TB X-Raid volume over 2 2TB physical disks (so effectively RAID1). One of the disks is failing so I want to do a straight-swap for a new 2GB disk. What is the procedure ...
Mar 11, 2019Guru - Experienced User
sebbelcher wrote:
I have an NV+ v2 running a 2TB X-Raid volume over 2 2TB physical disks (so effectively RAID1). One of the disks is failing so I want to do a straight-swap for a new 2TB disk. What is the procedure for this?
Just remove the old drive (NAS running) and insert the new one.
sebbelcher wrote:
After that I have an additional 4TB disk that I want to add to the enclosure as a seperate volume (so it doesn't get pulled into the existing X-Raid volume). What is the procedure for this?
Two issues here...
First, you need to be certain that you have a v2, since the older v1 can't handle drives > 2 TB.
An NV+ v2 runs 5.3.x firmware. If you are running something else (4.1.x or 4.2.x) then you don't have a v2. The labels are confusing... So if you aren't running 5.3.x, then post back and tell us what you are running.
Second, if you are running X-RAID you will need to do a factory reset, and set up the NAS in flexraid. That is destructive, so you'd need to reconfigure the NAS and restore the data from a backup. If that's an issue, then expand the existing volume instead.
- sebbelcherMar 11, 2019Aspirant
Hi - it's definitely a V2 (running 5.3.13).
If I expand the existing 2TB X-Raid (2x 2TB physical) with a new physical 4TB disk... how much additional capacity will be created? (I'm assuming not 4TB).
If I choose to go through the re-build route, what is the best way to backup the current x-raid volume. Can this be done directly over the USB port on the unit?
- StephenBMar 11, 2019Guru - Experienced User
The capacity rule is "sum the disks and subtract the largest". So adding a 4 TB drive would expand the volume by 2 TB. Adding another 4 TB drive would expand it by 4 TB.
You can use the USB port, or you can back it up over the network (say to a USB drive attached to a PC). I don't know which is faster with the v2. On the v1 it's no contest - the USB performance is very poor, so backing up over the network is much faster. If you do back up over the network, I suggest using software that can verify. Teracopy is one option, there are others.
Disks can fail during expansion too, so I recommend doing a backup either way.
Thanks for all your help with this.
Final question for you. If I go down the rebuild route, what's the order of play when I bring the system back up. Should I start with the two 2TB disks in and set it to Flex-RAID, then once it's configured those, add the 4TB disk in and it will auto-create a 2nd volume?
