TonyPinder
Jan 07, 2018Aspirant
ReadyNAS NV+ V2 HDD Locked
I appreciate that there are other strings on this forum that deal with locked HDDs however NONE give a public solution. I am completely lost as to how to unlock the 4 HDD that are locked in my NAS. ...
- Jan 09, 2018
I am receiving two email messages upon each reboot.
1. Missing shares detected (nas-A0-A0-5B)
The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume.
media
backup
2. Volume scan failed to run properly. (nas-A0-A0-5B)
***** File system check performed at Wed Jan 10 09:07:57 EST 2018 *****
fsck from util-linux-ng 2.17.2
fsck.ext4: No such file or directory while trying to open /dev/c/c
Possibly non-existent device?
TonyPinder
Jan 09, 2018Aspirant
Thank you very much.
I will know on next reboot but it does appear to be functioning very differently.(Better).
I really do appreciate you time and help with this.
Kind Regards,
Tony.
TonyPinder
media
backup
- mdgm-ntgrJan 09, 2018NETGEAR Employee Retired
I assume there's no data to backup, so do a factory default (wipes all data, settings, everything). This time don't select the Secure Erase option using RAIDar.
- TonyPinderJan 10, 2018Aspirant
Factory defult worked well and the reboot onlt took a few minutes.
Problem solved thank you.
I appreciate the time and help given.
