FrankLieder
Oct 11, 2019Initiate
ReadyNAS NV+ v2 will not power on
After years of service, my ReadyNAS is no longer powering on.
It will not turn on when the power button is pressed... no LCD and no fan. I don't think its the power supply because the network link light is lit and flashing.
Any ideas?
First of all, if your NAS has an internal PSU it is a v1 (the labels can be confusing).
A v2
- says NV+ v2 on the front chassis
- uses an external power brick
- runs 5.3.x firmware
A v1
- says NV+ on the front chassis
- has an internal PSU
- runs 4.1.x firmware
It could still be the supply (for instance 12 volts might have failed). Though normally the LCD will show something when the network LED is lit (they use the same power rail).
Try powering down the NAS, removing the disks (label them by slot!). Then power up, and see if it comes up with a "no disks" status.
It could also be a memory failure (which you could fix) or a system board failure (which is not repairable). Do you have a backup of the data?
- FrankLiederInitiate
Definitely a v2 (says on front panel and external power brick).
I've already removed (and labelled the disks!). No joy, still dead.
I don't have an explicit backup of the data as this is my TimeMachine backup system. I have other system backups, so not a big deal.
How can I diagnose memory vs motherboard failure?
Thanks!
Oops - my comment on memory only applied to the v1. The v2's memory is soldiered on to the system board.
- SandsharkSensei
StephenB wrote:It could still be the supply (for instance 12 volts might have failed). Though normally the LCD will show something when the network LED is lit (they use the same power rail).
Are you sure? The NV+V2 has a soft power-on circuit and WoL capability, which usually means a separate +5VSB bus for those functions, including the NIC (though still sourced ultimately to the 12V of the brick). If the NIC LED is on when the NAS is off, then goes off when the NAS is turned on (but doesn't actually go on), that could indicate too high a load for the power supply to handle, and could be a failing power supply. If the NIC LED stays on, it's probably because something is dragging down one of the other busses or the power-on circuit is no longer functioning, neither if which is repairable.
You know more about this topic than I do. The way I read your reply, this wouldn't be the power brick - it would be circuitry on the system board (which isnt repairable).
