mattson
Sep 14, 2016Aspirant
Readynas NV+ v2 XRAID2 does not utilise extra capacity on 4TB disks
Hi there,
I recently had 2 failed drives in my trusty Readynas NV+ v2 - 5.3.12 firmware - so decided to try my hand with 4tb drives, the only ones supported for the NV+ v2 were the WD Reds (can...
mdgm-ntgr
Sep 15, 2016NETGEAR Employee Retired
There will be an initial sync using the capacity of the smallest disk and once that completes if you have more than one 4TB disk installed it will then proceed to create a second layer, do a resync and expand onto that.
mattson
Sep 15, 2016Aspirant
Thanks for the reply mate.
I left it overnight, and it finished it's initial sync, but when that completed, it just remained at 5.4tb.
kinda frustrating :(
- StephenBSep 15, 2016Guru - Experienced User
Reboot it.
- mattsonSep 16, 2016Aspirant
Thanks guys - yes - post reboot and the volume successfully expanded to 7.4tb as expected.
woohoo :P
