mattson
Sep 14, 2016Aspirant
Readynas NV+ v2 XRAID2 does not utilise extra capacity on 4TB disks
Hi there,
I recently had 2 failed drives in my trusty Readynas NV+ v2 - 5.3.12 firmware - so decided to try my hand with 4tb drives, the only ones supported for the NV+ v2 were the WD Reds (can...
mattson
Sep 15, 2016Aspirant
Thanks for the reply mate.
I left it overnight, and it finished it's initial sync, but when that completed, it just remained at 5.4tb.
kinda frustrating :(
Sep 15, 2016Guru - Experienced User
Reboot it.
- mattsonSep 16, 2016Aspirant
Thanks guys - yes - post reboot and the volume successfully expanded to 7.4tb as expected.
woohoo :P
