Nick_Nandhra
Nov 24, 2014Tutor
ReadyNAS nv+ V4 RND 4000 (DISKLESS) #24176805
Hi, I am in need for some advice. Mt NAS drive failed due to a power cut. The unit will power up and will not boot (the led on the backup button flashes fast). I am hopeful that I will get a replac...
mdgm-ntgr
Nov 24, 2014NETGEAR Employee Retired
So this is the NV+ with a charcoal chassis and an external PSU?
If so the boot menu for your device is here: http://kb.netgear.com/app/answers/detail/a_id/21104
If not, please note that the boot menu procedure is different.
Can you access the boot menu? If so can you try an OS re-install?
