Nick_Nandhra
Nov 24, 2014Tutor
ReadyNAS nv+ V4 RND 4000 (DISKLESS) #24176805
Hi, I am in need for some advice. Mt NAS drive failed due to a power cut. The unit will power up and will not boot (the led on the backup button flashes fast). I am hopeful that I will get a replac...
vandermerwe
Nov 25, 2014Master
1. You can mount the array on a linux system.
2. If you are going to buy a new readynas, I believe Netgear may be able to help you to migrate your data onto the new system.
Of course if Netgear give you a new Nv+, you can put the drives into the new unit - ensuring that you first set it up with new firmware.
Edit: I see you have another thread open relating to this and received the same advice, you cannot just put the disks in and you will lose data if you do. Contact Netgear and follow their advice.
