Nick_Nandhra
Nov 24, 2014Tutor
ReadyNAS nv+ V4 RND 4000 (DISKLESS) #24176805
Hi, I am in need for some advice. Mt NAS drive failed due to a power cut. The unit will power up and will not boot (the led on the backup button flashes fast). I am hopeful that I will get a replac...
Nov 27, 2014Guru - Experienced User
A duo v2 would also work, since you only have 2 drive.
Another option is to try to mount one of the disks in a PC with linux boot disk. Someone from Netgear can probably get you the mounting commands (they are published for the v1, but perhaps not for the v2).
