ktupper
Jun 02, 2017Aspirant
ReadyNAS NV+ Won't Power Up
Help! I have a Ready NAS NV+. It's been quite reliable until now. We moved homes so I shut it down through the admin panel. Carefully packed it with my desktop and personally transported it to ...
ktupper
Jun 03, 2017Aspirant
It doesn't do anything at all. It acts like it's not even plugged in at all.
Where is the Ram Module?
fbmachines
Jun 03, 2017Guide
Under the cover.
- ktupperJun 03, 2017Aspirant
Not the RAM module.
Still no power at all. I think it may be the PSU. I do have one of the serial numbers referenced below.
https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyNAS-NV-won-t-power-up/td-p/666755
A small percentage of ReadyNAS NV (revision B) and NV+ owners with low-noise fanless power supply unit (PSU) may encounter a premature failure of the PSU due to elevated temperature. The ReadyNAS systems affected have Serial numbers between 000DA2010FFE and 000DA2016000.Although the warranty on Infrant-branded units is only one year, if your SN does fall within range, you should contact Netgear support for your area to arrange for a replacement.
- StephenBJun 03, 2017Guru - Experienced User
ktupper wrote:
Not the RAM module.
Then you should be able to get a free PSU replacement, even though you are out of warranty.
- JennCJun 07, 2017NETGEAR Employee Retired
Hello ktupper,
I think the support team have recently stopped sending free PSU for this legacy NAS as they have very limited stock. I believe they currently have 0 stock for it.
- ktupperJun 08, 2017Aspirant
Correct - I called and they gave me the part number to order it online elsewhere.
