marcintalarczyk's avatar
Aug 05, 2024
ReadyNAS NV+ [X-RAID]
Hi All
I have old Netgear NAS NV+ with 4 bay.
Work only 2 bay.
Any one have idea why 2 others bay are unactive??
  • StephenB's avatar
    Could be a chassis failure I guess.
    Have you tried doing a test install on a 2 TB drive in slot 1?  Then power down the NAS, and see if you can boot the NAS with that disk in other slots?
    • marcintalarczyk's avatar
      marcintalarczyk
      I have 4 500GB disks loaded. It only sees 2. I swapped disks. It sees all 4, but only two slots are active. Two slots damaged, i.e. slot 3 and 4??
      • StephenB's avatar
        I suggest trying the test above - note you can use any disk of 2 TB or less.
  • Always the same two, or it will only handle two drives (in any two slots)?
    If the former, probably a bad SATA backplane, but could be the SATA controller on the main board as well. Not repairable except by replacing the bad board.
    If the latter, a power issue.  But IMHO, replacing the power supply in an NV+ isn't worth the investment.
ProSupport for Business
