jjames1
May 14, 2014Tutor
READYNAS NVX POWER SUPPLY
Does anyone know a parts number for the ReadyNas NVX rndx4000 is out of warranty, just wanting to buy the PSU a link to where to order would be great
xeltros
May 14, 2014Apprentice
You can do it the easy way, use tech support and ask for a replacement. They will give you the right model number to purchase and they even may send you a replacement (at a cost, except if your power supply is in a faulty products list, I believe I read some NV models are on this list.)
