jjames1
May 14, 2014Tutor
READYNAS NVX POWER SUPPLY
Does anyone know a parts number for the ReadyNas NVX rndx4000 is out of warranty, just wanting to buy the PSU a link to where to order would be great
xeltros
May 16, 2014Apprentice
Each and every new Netgear NAS runs the same operating system. The only difference is that x86 models have more available packages via apt-get/aptitude than arm version.
After that your concern is more about speed (ARM version speed never gets faster than 100Mbytes/s in read due to CPU limitation), HDMI port and the number of bays. SSH is available for all OS6 models along with replicate. There is no licensing needed for those. You of course get active directory integration and snapshots feature too. 314 model is not rackable though.
Important thing to know is that you can't just switch disks from the NV to the 314, they are not using the same OS. So you'll have to backup/restore so you may want to be considering all your possibilities (IE other brand/models, custom made NAS with freeNAS (AM1 socket is 25W for example)...).
