PeterWB
Jan 07, 2014Aspirant
[ReadyNAS NVX] Upgrade HDs to 3 TB
As my Netgear ReadyNAS NVX Business Edition is nearing maximum capacity, I'm planning to upgrade the HDs to a larger capacity model. Current setup: 4x Western Digital RE3 Enterprise Edition 1 TB...
Jan 07, 2014Guru - Experienced User
Yes. Though if you have gigabit ethernet, you will find it is actually faster to connect the drive to a PC, and back it up over the network.
