tigerten
Jan 28, 2024Luminary
ReadyNAS OS 6.10.10 released
Link to download: https://www.netgear.com/support/product/readynas_os_6#download Release Note: https://kb.netgear.com/000065999/ReadyNAS-OS-6-Software-Version-6-10-10 Cleaned up a b...
Dewdman42
Feb 18, 2024Virtuoso
Unfortunately I did not read the notes about the release and did not realize they are removing the ability to install apps. WTF? that si utterly brain dead. How can I revert back to 6.10.9 now?
As a secondary question, is there a way to install deb's other then using the front view menu to do it? I don't mind using SSH that's fine. But unless there are specific bug fixes or other improvements, this update seems like a complete downgrade, and for no apparent reason.
And you say they did something to make apt use not function correctly anymore? please elaborate on that also.
good4y0u
Feb 18, 2024Star
You might be interested in my post here that helps you go to the Debian Archives for your package manager https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Fixing-apt-update-repo-issues-and-key-errors-on-ReadyNas-628x/m-p/2359659#M201025
