JenniferK
Sep 14, 2016Aspirant
ReadyNAS OS 6.2 Communication error
Hello, We purchased the ReadyNAS OS 6.2 and when I try and set-up the storage system, it gives me an error that states "ReadyCloud temporarily lost communication with your storage system". It did...
JennC
Sep 17, 2016NETGEAR Employee Retired
Hello JenniferK,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JenniferK
Sep 20, 2016Aspirant
Thanks, JennC.
I was able to get Netgear running.
Best,
Jennifer
- JennCSep 21, 2016NETGEAR Employee Retired
Hello JenniferK,
Great! I'm glad you were able to make it work now.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future! We appreciate each and every contribution you make. :)
Regards, - JennCSep 21, 2016NETGEAR Employee Retired
Hello JenniferK,
