olest
Aug 13, 2013Guide
Readynas OS6 future requests
1)
Snapshot function on Home folders.
2)
Snapshot cleanup Schedule/option for each share, e.g. be able to set that only snapshots up to 30 days should be kept - Automatic delete older snapshots
3)
Option to start ReadySYNC client automatically for each NAS on Readynas Remote client
4)
Add an ignore, delete or quarantine file option to virus detections
Also see my buglist at http://www.readynas.com/forum/viewtopic.php?f=154&t=72312
2)
3)
4)
- super_poussinVirtuosofor the 4) did you try to install antivirus plus addon ?
- olestGuideNot until you me about it :)
With Antivirus Plus you can only select a default action - not a selection for each file detected.
But it is better that without antivirus plus addon.
And the report and block still have a bug with an log/email every second - whsbussAspirantI surely hope adding user quota would be on Netgear's short list. That's my most needed feature at this point.
- fordemMentorAuto power on after an unattended UPS shutdown.
All of my hardware is fed from a single APC rackmount UPS and in the event of an outage will do an orderly shutdown either via SNMP or APC's network shutdown software, all except the RN102 can be made to power back on unattended when power is restored - the hardware can be made to power on automatically, because when power is applied it returns to the "last state", if it was on, it comes back on, if it was off, it stays off - all that is needed is a way to enable an automatic power on through the settings page. - ljungTutor1. Option to be able to backup a selected file/share to skydrive and/or gdrive.
2. Ability to dlna-share video files from whitin rar-archives (like the xbmc dlna server can).
3. Restart/halt from web-interface (guess it could be done from ssh witch shutdown -r/-h 0).
4. Option to be able to spin down drives, at least 7200rpm drives.
5. Ability to decrypt drives from remote, uploading the key-file over a secure connection etc. - mdgm-ntgrNETGEAR Employee Retired3. You can already shutdown/reboot the ReadyNAS from the web admin interface.
- ReadyASGuideI had the functions in OS4, but they are missing in OS6 - I need them back:
1. More than one email address field for alerting (is only in OS6 1 instead of 3 like in OS4).
2. More detailed SMART report (should be detailed as in OS4).
3. Possibility to schedule switch off the NAS only (in OS6 I should define on and off simultaneously, but I need only off).
4. Correct RAIDar status is needed - look at: viewtopic.php?f=7&t=73807
5. Possibility to connect to ReadyNas with OS4 for UPS status (I can link OS4 NAS with OS4 NAS, but no OS6 NAS with OS4 NAS connected to UPS). - StephenBGuru - Experienced UserYou can do (5) - my RN102 shares the same UPS as my NV+ and duo v1.
On (2) If you have a mouse with a wheel, you can see most of the SMART stats from the UI (the SMART window scrolls). But if not, you do need to download the logs. I agree that is a pain. - ReadyASGuide
StephenB wrote: You can do (5) - my RN102 shares the same UPS as my NV+ and duo v1.[...]
So, should I try connect UPS to USB of my Ultra with OS6 and share for Pro and NV+?StephenB wrote: [...]On (2) If you have a mouse with a wheel, you can see most of the SMART stats from the UI (the SMART window scrolls). But if not, you do need to download the logs. I agree that is a pain.
Thank you! Yes it's a pain. For instance I can't do it on my laptop, I should connect the mouse.
In my opinion NTG should change it in newer versions - SMART parameters easily presented. - ReadyASGuideMy 5: there is no case with UPS. Thank you again StephenB!
viewtopic.php?f=10&t=74853
